peakandscoot
I am replacing my tapered axles but have a few probably simple questions.
1. I am reading at this point i can use my dent puller and yank theses out. Yes?
2. My new set up came with new studs for the rear end housing. Whats the best way to remove the old ones. Just beat them out or do i need heat?
3. when installing my new axles do i need to lube the outside of the green berring. Im assuming i should at least lube the o ring.
4. Anything i should look out for while doing this whole thing?
Thanks for the help
Thanks for the help
