Changing Therostat
Mopar69 Bee
2:39 PM
Ontario
Needs some help!!!
Trying to change thermostat but housing is stuck to water pump pretty good. Any tricks or ideas how to get it loose without breaking it? Any help would be appreciated.
Cheers
Good luck. Sealing again could be a challenge. Everyone has advice, mine is to get a molded hose, put in a Napa/Stant 180 Superstat, and the only neck that sealed for me is the Mancini Billet.
Thanks for the advice. It's all back together. Here's a pic. I'll take it for a rip tomorrow. Hopefully it all sealed good.
Started filling rad slowly. Drain is snug but fluid started coming out. Any ideas? It was ok before I loosened it to drain.
Out of curiosity did you use gasket sealer on your thermostat housing?
Yes I did. It sealed great. No leaks. Took it out tonight for a drive. I ended up putting a new butterfly drain plug in. All good now. Thanks.
The reason I asked, I don't use sealant with the Fel-Pro gasket, never had a leak.
