I put 11x3 drums on my 65 Dodge new shoes, wheel cylinders, hoses, springs and cut drums. Then switched to disc's, was able to use shoes and drums on my 66 Satellite. The other stuff is in a pile, dollars down the drain.
Kid.. I admire your conviction!Well I thought I would go this route first. I'm reminded of a friend back in the day running a '62 Savoy, built up 383 running in the tens. He would use up the whole shutdown area at one of the local tracks we ran at. He had drums all the way around. Also the '64 Polara 500 I once owned had standard brakes and a single master and I don't ever remember having problems stopping that tank. If I don't like the setup I'll go with disc.
Made a video "Packing Wheel Bearings" Did a little experiment halfway through.
I have new dust caps on the way.
Checking the 7 x 15" wheels for clearance.
Here's the last set of drums I ordered. (Check out "Rant" thread. Damn things are cracked.
Well anyway I did use them to bleed the brakes.
Here's my helper. Stinky cheese container, Pringle can with a section of chain inside for weight, section of hose.
Make sure the hose is submerged in fluid. Right rear, left rear, right front, left front. One time for each wheel and I had a solid pedal.
I ordered tires today. Next I'll be painting the wheels so they'll be ready for the tire shop.
Kid,The work looks Great!! Curious of your tire sizes, and, what are you doing for hub caps? Also wish I had a nickle for every wheel bearing I packed that way back in the day!
Hey Thunder, thanks for the compliments!
I bought 7 x 15" x 4.5 b.s steel for the front, 8 x 15" x 4.5 b.s for the rear. 275/60/15 Cooper Cobras for the rear. 225/70/15 Cooper for the front. I'm second guessing the 225s for the front. That's going to be cutting it close in the fenderwell. I measured from the hub to the front, inside lip and a 28" is tight on this '62. I posted a thread to this question.
http://www.forbbodiesonly.com/moparforum/threads/anyone-useing-225-15-on-the-front-1962.137155/
I bought the wheels from a vendor at Chrysler Carlisle last year, he makes them himself and these take the smaller 9" caps, if I would decide to go with caps. I probably won't use any.
You and I could go and have some great steak dinners for all of those nickels!
Thank you Sir!Nice job sir!
Keep on keeping on and you will be done before you know it!
Hope the tire shop & parts house come through for you.
I love white cars....just look so clean!
Kid.. Looks like you are wrapping things up! Wheels look factory fresh! ...Lawn looks Fantastic Too! Freshly Cut?? LOLSanded all four wheels, primered, sanded again, painted the insides black, painted the outsides body color. Shop's a mess. I'm beat!
I was getting ready to clean the spray gun, still had about a half pint left, then remembered I had some miscellaneous parts that were prepped and needed paint. Glad I remembered!
Hopefully the tire shop will call Tuesday and I can get them mounted. I have the heat cranking to 80 degs in the shop. Another set of front drums suppose to be at the parts store on Tuesday also.
View attachment 510322 I understand..Dad's should be respected with the "sir name".
Trying to get the 65 buttoned up, the rain will slack off in the next month or so, hopefully.
I'm glad you like my 65, it grows on me the more I look at it.
I like the Belvedere II more than the Satellite personally, due to the body side moldings I guess.
I like all the 62-65 B Bodies, they are so odd and uniquely designed.
( some of them are "so ugly they are cool") quote I've heard and made myself at car shows!
Wasn't it Dillinger who tried to obliterate his fingerprints? Well if you go crime waving......and get caught..... Can I have dibs on the Polara?!Getting closer for sure. But you know how it goes, you're never done. I might take the day off, or not. Need to get the shop back in order at least. I need to refurbish the drive shaft. I have a new boot and u-joint and of course it needs a little paint. So we'll see.
This would be a good time to commit a crime, I haven't any finger prints after all of that sanding!
I mowed Thursday (at least once a week). We're getting a shower here when it needs to and it's been right cool for the month of August.
Thats a sweet Belvedere![]()
I won't get caught.Wasn't it Dillinger who tried to obliterate his fingerprints? Well if you go crime waving......and get caught..... Can I have dibs on the Polara?!
