- 10:06 PM
- May 14, 2011
- On the Ridge, TN
I do think there may be something to the Carter/Eddy carbs being more susceptible to the problem than the Holley design based carbs are.The 850 Demon in my 440/493 Charger can sit for weeks and still start up fine. THIS is even with the California blend of pump gas. NO spacer, NO electric pump.
The Holley 600 in my 75 Power Wagon can also sit for weeks and still start fine. Neither has a functioning choke either.
I had a 73 Dart Sport 340 with a ThermoQuad. It was hard to start when cold or after sitting a few days. I blamed the problem on the accelerator pump....BUT once I attached a proper choke to it, it started up easy even after a month of sitting. No ****, I was shocked! For years I have bitched about ThermoQuads being a POS carb but maybe I was to blame the whole time!
Never had this issue with the old 3310's I used to run - but then, the gas was different back then (no ethanol), too.
