1967coronet440
Thanks, NGK have great reviews I’m gonna start with a set of thoseAs for plugs, you need to 'read' them and see what's up.....
Thanks, I’ll be running the 6-AL digital box so I’ll look at resistor styleMsd recommends a resister with their boxes. I run resistor plugs in the dart and rr. 511 uses a BKR6E. Readily avaliable at the auto parts store for around $20 a set. That's at 10.5. If your up over a 11 try the BKR7E
Now I'm curious, is a BKE 7 hotter(?) and why go there with higher compression?Msd recommends a resister with their boxes. I run resistor plugs in the dart and rr. 511 uses a BKR6E. Readily avaliable at the auto parts store for around $20 a set. That's at 10.5. If your up over a 11 try the BKR7E
Resistor type stop 'popping' in radio & the same for everyone near you, including TV's going crazy when you go down the road(at least back before cable)!
That is not true. The thermostat DOES control the operating temperature.You guys know that the thermostat does not set the operating temp of the engine, right?
It only sets the time it takes to warm up.
Using a low temp tstat means you are subjecting your engine to longer periods of low temperature operation during the most damaging time- cold.
Because I have electric fans with a very accurate Dakota Digital controller, I use a 160 and let the fans regulate the top temperature I want. Set at 185 (on) and 178 (off) they cycle accordingly. On the highway the temp reads 175 and the fans are off. In the city they come on at 185 and hold that.I have a 512 stroker.Looking for suggestions on what temp thermostat to use on my 535”.
180, 160?
I have a fast 2.0 on my 505, but only running one elec. fan w/ a mech. belt driven fan. Haven`t had the need for a second elec. Ina 68 barracuda fastback , there aint much room for a second one anyway.It is a a Street strip car, by street I mean just cruising to local shows now and then. I do have a fitech 1200 up top that can control both fans so I’ll have that set up also. Think I’ll try the 180 first and see how that goes.
Pretty simple. Depends on the type of ignition you have, and type of plug wires used.Can someone school me on resistor or non resistor plugs?
Nothing, it runs unregulated. Probably way too cool.So...what happens if you remove the thermostat entirely?
What sets the operating temp and what is that temp?
