Ski 61701
- 9:39 AM
- Nov 21, 2016
- Bloomington Illinois
Jordan, looking at the pic of your carb / intake it looks as if you are running an oem intake manifold. With that being said you might need to get a conversion style carb spacer to go from thermoquad base to afb carb base. So before you go buying stuff take a good close look at the bolt spacing on the existing carb and make sure the bolts are all equidistant. I wouldnt be suprised that you have an old transdapt carb spacer on it. Not sure if anyone makes an aftermarket phenolic or wood staggered carb spacr.
Like others have mentioned you need to check timing and get it somwhat close to stock and see what your temps are. Also have you moved your metal fuel filter off of the rocker arm cover?
