dvw
It has at least 3/4". The nice thing about welding it is that our can tip the loop what ever angle you need. I cut the 90 degree ends off from the floor mounts. Save these cutoffs. Then tack weld bolts into the holes. Drop these parts in from above the floor under the carpet with the bolts sticking down through. That way the loop can come off easily without having to lift the carpet. As for aluminum shafts. My 9.0 raccar has 500 passes on one, no issue. You'll find steel shafts aren't even legal in Pro-Mod. What does that tell you?DVW looks tight between the driveshaft & exhaust. How much clearance do you have? I'm thinking of either a carbon fiber or aluminum drive shaft. The carbon fiber needs to kept away from heat of 200 or higher if I remember correctly.
