How did we get to carb adjustments to correct the timing events?????
Without testing I would say the Vac can isn't holding so it's probably got a leak.
We have a way to set limits on the vacuum can stroke and we have Vac Cans that can read down to 8-10" of vacuum. If you need it any less than that you probably should be running a all mechanical distributor or get a valve job done.
