Sounds like we need to quit talking and start investigating. If it isn't in the driveshaft (universals) or the rear then yank the tranny and get to work. My bet is it's a bearing.
This is very plausible. The bushing is/was new, but the tranny fought like the dickens to go that last little bit into it when assembling everything.
I can follow that logic, yes.The pilot bushing noise would be evident when the clutch is depressed.......
With the noise being constant above a certain speed I lean towards a bearing......
This one is a high-dollar CenterForce Dual Friction setup. New flywheel, factory 11" cast iron bellhousing, the works, all new.pull the inspection cover off the bellhousing and look for clutch disc problems. 23 spline clutch discs aren't always well made.
Yeah, that's next, risky as it is. Downright scary, in fact.sounds like its time to put the rear on jack stands and have someone run it up to speed while you listen
No sir. Nowhere near normal. Sudden new noise, like a gigantic pissed off hornet under the hump, happened after an enthusiastic clutch dump into 2nd yesterday. The noise/buzz is accompanied by a slight, discernable vibration.Sounds normal to me. Seriously it does, but I know where ur coming from. Bearing at frt of trans or rear of case is my guess, not the bushing in tailshaft.
85W90.Can’t really see with the flash- 85w90? Maybe try 85w140? Cheapest 1st try, but you already had it out on the road. This crap just wants to make you give up,BUT you still got the rest of your life. Think kinda positive. Jeff
Nope, got louder the farther back I pulled the phone, loudest at the end of the video close to the hump behind the shifter. Definite mechanical sound to it there, well defined. If you think about it, makes no sense to come from the front of the tranny, since gear/engine speed/clutch in or out have no effect.Jeez that is odd, definitely sounds like it’s from the bellhousing area. Time to drop the trans, get to work
Hard to tell from a phone video, either way time to drop it.Nope, got louder the farther back I pulled the phone, loudest at the end of the video close to the hump behind the shifter. Definite mechanical sound to it there, well defined. If you think about it, makes no sense to come from the front of the tranny, since gear/engine speed/clutch in or out have no effect.
Yep, I want to say tailshaft bearing. Sort of makes sense that the tailshaft bushing was pretty much gone, probably from play caused by the bearing.Geeez, sure sounds like ya' got a beehive in there. Reminds me of worn/dry bearings.
You didn't mention if you took the speedo cable off. That is a low pitched buzz. I don't think it is a bearing . Kinda sounds like something rubbing on teeth of maybe a gear or the flywheel. You might try taking off the shifter boot and then maybe figger out which area the sound is coming from. Puzzles me that the tranny needs warmed up before the sound comes in. You might try inspecting the speedo drive before taking the tranny out. Sounds like possibly the plastic teeth to spiral gear interference.
With it warmed up to the point it makes the noise, you might try , tires off the ground , tranny in neutral, turn the driveshaft with your hands and see if you can feel any roughness in the driveshaft. .......................MO
Thanks, Mo. Yes, it does have a definite "geared" sound to it. No, I haven't gone to the speedo drive yet - I figured if it was something like that, it surely would have chewed the plastic off the speedo gear pretty quickly? It sure is persistent and predictable - and sort of heavy for plastic? I dunno.I expect you have checked for yoke play in the tail of tranny, and the rear U-joint&yoke? Those things will make a buzzing-vibrating sound . Of course you have checked U joints being in phase?? Don't pull that tranny till you have exhausted all other possibilities. Pull the clutch cover off the bottom of bellhouse and check , noise can transmit to other places.................................MO
