- 7:18 PM
- May 14, 2011
- On the Ridge, TN
Thanks. That could very well wind up being the culprit. the noise is emanating from that part of the transmission.does the oil show signs of metal. rear bearing on tail shaft spinning inside the housing under load.
just guessing but under load and torqued up to road speed could be a binding bearing in the housing.
If it winds up not the speedo cable, this will be the safe bet answer, in fact - which means this transmission is outta here if that's the case.
