khryslerkid
- 11:24 AM
- Mar 10, 2010
- Hanover, Pennslyvania
I'm installing the rubber roof rail seal on the '62 and I'm needing a couple of good pictures of exactly what it suppose to look like after the installation. My original was way too deteriorated to tell what was what. 1963 should be the same also.
I'm seeing on the new seal that there are two different designs or profiles molded together. So I place the seal where the joint starts, centered at the two windows. This has the pointed front of the seal about two inches foward from the original location.
Now does the seal at the rear quarter window suppose to fit over the glass like this?
Or behind the glass like this? I can make it work either way.
I'm also wanting to see what things suppose to look like just above the door handle where everything comes together with the quarter window seal.
Any help would be greatly appreciated. I've read about these seals not being exactly correct but I'm thinking the ones I have can be modified enough to do the job. TIA
