- 9:36 AM
- Apr 13, 2012
- Granite Bay CA
What the heck??? 18 years ago, March 12, 2000....I bought the 1970 Charger 500 for $1700. It ran and drove great. 318, 904, 4 wheel drum brakes.
A lot of improvements have been made over these years. Today I was heading down to weigh the car before I started taking the stock A/C stuff out and swap in the Classic Auto Air stuff.
It was easy to start but ran a bit rough and stalled a few times until it warmed up. It was 75 degrees today. I was at a traffic light and the car stalled and would not restart...spinning the starter but no start. It acted as if it were out of gas. I was lucky to roll it downhill and through a left turn to a wide shoulder to park safely.
I had gas but no spark. The car ran great yesterday, zero troubles in about 20 miles of cruising around. I have a MP electronic distributor, chrome box, a 1.0 ballast resistor and an MSD Blaster 2 coil. I had the wife come get me. We went back to the house to get a few tools and parts. First up I tried pulling # 1 plug wire and stuck a spark plug in it. I spun the engine and got no spark. After that, I replaced the ballast resistor because it felt as if the engine wanted to start as I released the key. The replacement ballast is a .6 ohm, pretty close to the other. It did not help, still no spark.
Must be the spark box, right? No....the replacement box did not help.
I checked the air gap in the distributor. It was at .014. The spec is .008, again, not enough off of the mark to stop the engine from starting and running.
Lastly, I replaced the coil with some generic unlabled black coil from the parts stash. It instantly fired up and ran. Why? The MSD coil looks fine and isn't that old. I got it back home and decided to put the original chrome spark box back in. It was difficult to start and ran the battery down. It is an Optima battery and is not simple to charge. You have to attach jumper cables to another battery and then charge the other battery.
Happy birthday, huh?
