Great posts above
I don't think they sell those anymore I had my sealed power catalog a couple of days ago and boxed it up now can't find the box
at least he won't have to worry about tagging the valves
mopars wear well but I'd mike the bores and if ok ridgid hone medium coarse- inspect for funny spots- then bottle brush fine and some new rings
Those pistons may be "compensated" .015 less than the stock piston they replace
did you find the compression height on those pistons- we can double check the deck clearance
what gasket did you do the compression with- you might want to go with a thin one BVVC with MLS without proper finish on the decks
I would not be tempted to mill the *** out of my new heads trying to chase compression
better off getting the intake close point early[/QUOTE
They still sell those pistons. P/N is 350NP 30 (.030 over) cast flat tops with 1.990 compression distance. Let me clarify please....this engine is not being done. It was rebuilt by the previous owner of my car back in 2000. It's not driven much, but I got the bug to do stealthy hot rod stuff while keeping it stock looking. Thanks for all your technical advice. My skills and work space is limited, therefore I have lots to learn even though I've been into Mopar muscle since 1977. Having a hot rod and apartment living is kind of a rough combo.
