wyrmrider
I would not buy a new XE256H for a Chrysler- it's for Chevy's but since you have it it approaches the intake closed point to build dynamic compression requirement Intake Closes 54.5 ABDC at .006 - much better than the stock MOPAR cam
so use it with the correct springs- maybe beehives check your retainer/keeper to stem seal clearance- usual stuff
you could stick some 1.6 rockers on the intakes and have a .478 intake open
to start I'd keep the stock manifold and carb- It's actually a very good carb for what you want to do- but then I raced lots of them
new timing chain and some headers
spend the money on the bellhousing- there are several ways to do that, and your headers
get it on the road and start thinking about heads later - your motor home heads- you could blend the bowls yourself
but new heads is a much bigger project what with new rockers etc-- U can use IQ's flow numbers for the time being
already have the 3:91s?
A .904 optimized grind would give you .475 to 461 intake lift at that 256 duration with 1.5 rockers and bigger at .200 but the 1.6 rockers do about the same thing
you need to spend some time on the dist curve-- IQ can guide you there
just do not try and do too much all at once
drive it while you look for an aluminum dual plane- lots of mag articles showing which ones work
