idrivemopar
Don’t know the ounces, but filled it till the gauge was in the green/full zone.
Did not evacuate. All new parts. Is it required?
AC was on the 318 2 barrel. Swapped for a 360 4 barrel. Would think thats enough engine.
Its not a matter of having enough engine, its that there is more demand put on the engine at idle, so, a idle solenoid is used on stock applications to increase the idle speed when the AC is on by actuating the plunger the throttle shaft is not allowed to return to regular idle position. Here is a picture of an AC idle solenoid on my 73 340 RR, this is on a thermoquad carb, and is attached to the AC circuit, so it engages when the AC is switched on.
