LeapYear
New Member
I installed a Powermaster XS Torque Starter in my 1967 Plymouth Satellite (freshly rebuilt 383 big block running just under 10:1 compression).
Starter works great on cold starts, but will only spin and not engage the flywheel on a hot restart.
Thought it might be related to the battery cable, so I purchased and installed a new cable – Still has same problem.
Next step is trying a heat shield, but thought I’d check for opinions on anything else that might be causing the problem.
Never had this problem before the rebuild with the old factory type starter.
