- 6:11 PM
- May 14, 2011
- On the Ridge, TN
So y'all know I'm running one of the Mancini-sourced reproduction "hemi" fuel pumps, the kind you can take apart and rebuild, right?
I think it's eaten another pump pushrod. Pressure gauge is only showing 4psi at the rail at idle and the thing is starving on top end in 3rd gear under spirited driving.
I'm starting to think the spring pressure in the fuel pump is excessive - that or they just don't make pushrods like they used to? This one is the fancy Comp Cams one and this pump ate a stock pushrod before that as well.
Thoughts?
Thoughts?
