sputnik 440
Capt Jim
I have been having fuel boiling problems with a 440. compartment is extremely hot partly due to 2" headers. The holley dp 4150 sits on a 1/2" insulator but it is little help. The 40 micron holley filter is in front of the carb and just before the fuel log. Having read threads related to the topics of fuel boiling out of the carbs, and in my case probably the filter as well, and threads on vapor lock at the mechanical pump, I bought a filter vapor canister with a return line and will mount it as recommended, just past the pump. I have insulated the fuel line from the upper portion of the ss/rubber line going to the filter and the filter and the fuel log. However, I want to put a holley regulator with dual supply lines and RETURN line. Now, will I have problems with running a line to the gas tank and, somewhere in that line, splicing in the return lines from vapor canister and the regulator? All my lines are 3/8", why did Mopar go from a 3/8" outlet on the pump to a 5/16" inlet and outlet on the vapor canister? I then go back to 3/8" after the canister to the fuel log and carb. Will the pressure drop effect the fuel pressure at the carb and therefore the performance?
