More bs from GM lovers
Them other guys cant't count past three, so why the concern, besides an old beat up mopar would be past them in third gear, whats the point of a fourth?
I'll be dsmned it does.
Mind blown....
Had a 66 Mustang Fastback with a 289 and a T-10. 1-3 was close ratio but 4th sounded like OD. With a Torker intake, headers and 600 Holley DP (the engine was a lower compression unit originally with a 2v) it would run a 15 flat which wasn't too bad for the day especially with 2.80 gears. Hey, it got 21 on the road tho! Never needed 4th at the track either.
Base engine for a road runner was the 383 and none of them came with a 3 speed on the column. You could get a Charger with anything from a /6 on up.....
The 70 Charger I had was a 318 3 speed on the column. It had a bench seat,no radio, and a design pattern where the clock went in the rallye dash. It was yellow, with a black vynal top and interior. It had painted yellow wheels and dog dish hubcaps. It was a real striped down car for a Charger. I had my yellow 70 Charger R/T SE 440 4 speed Dana car, and I used this striped down yellow Charger as my daily driver. I cloned up the 318 Charger to look just like my R/T. I put all the R/T trim and scoops on it,the same magnum 500 wheels, and dual exhaust on the car. They looked like twins! The 318 car got 18 miles to the gallon, and the R/T got about 6 miles to the gallon when driven properly. My girlfriend liked the bench seat too. I never registered the 318 car,I just swapped the plates back and forth between the two cars. Whenever someone wanted to race,I would tell them that I had to go get gas,and we could race when I get back, and I would swap the plates onto the R/T,and go kick some ***! Those were fun times!
