Yes, I got the complete disc front, drum rear, w/ dual master cylinder, conversion kit from them. I'm using their ss brake lines as well. Are the lines a perfect reproduction of the originals?I just did an internet search and found that Right Stuff has a couple of Max Wedge kits (3 lines) listed on Amazon right now. RKT6401 - $46.31 or RKT6401S - $65.23
I don't know?
I will tell you that everything was good quality and all the lines hooked into the clips and easily threaded into the fittings, wheel cylinders and calipers.
Not cheap, but good quality, never is.
my computer still playing tricks, who wanted the radio delete plate please re contact me.
That was me but your settings won't allow me to pm you.
wow, OK. I'll see why my settings wont allow the PM, I'd really have no issue posting my e-mail address online though. give me some time to work on it. this site is confusing to me, but I'm old..That was me but your settings won't allow me to pm you.
I think?? I sent you a PM. my only and last project is my '64 Dodge 330 sedan, having real steering issues though. the drag link is in a bind when the idler is hooked up? VERY hard to turn the wheels, even off the ground.No worries Geri. You can try to pm me if you like then maybe I'll be able to respond to your pm.
I'd like to see some pics of what you're working on.
No not the steering box, I just put a new one in. the problem seems to be in the idler when it is tightened it locks the steering, with the fittings loose it does not want to align with the tapered hole in the drag link and in the cross member- I ordered a new idler- hoping this one is bent , if it isn't that means the cross member is bent at the anchor for the idler.Very nice 330. This is what I was looking for when I bought the convertible.
Is the problem in the steering box?
I don't think I'll need that but thank you. it looks like the former owner mixed and matched parts, wrong oil pan, with tie rod rubbing on it, -many other details, but I'll get through it, I enjoy the chase..Happy to measure my idler and centerlink to compare with if needed.
