- 8:45 PM
- Apr 13, 2012
- Granite Bay CA
Not sure that I get you point.
SOME people like to run staggered sizes, larger diameter wheels and have made a few changes. Asking for a 60 year old tech means that the guy MAY have been around in the 80s when these cars were still in use as compared to today. New cars have no adjustment other than TOE, right? Trucks like my 2007 Ram have eccentric cams on the lower control arms for caster and camber but what cars have that? If a 20 year old guy learns how to align the types of cars most likely to come into the shop, he will have zero experience with a classic Mopar, Ford or GM car.
In two instances about 7 years apart, I had cars with Moog K7103 offset bushings installed to get more caster. Both cars were taken to the nearest shop, a "Les Schwab" about 6 miles from home. In both cases, the monkey could not get even 1 degree of caster. Neither car had been wrecked. In both cases the cars were taken elsewhere and both were properly aligned. The Duster attained 2.8 degrees of Caster and the 71 Road Runner was over 3 degrees. The Les Schwab guys just did not know what they were doing, plain and simple.
Yes....In both cases, the Les Schwab guy was barely old enough to shave.
