- 11:42 AM
- Dec 4, 2009
- Pasadena, Texas
Well, at least it didn't get built backwards!
Because I don't know , the posts are set in the ground like fence posts , then the frame is completely finished ?
Once all the building is complete the floor is then poured inside the structure like flooding a hockey rink that's been framed ?
Looks nice. What are the dimensions? (maybe i missed them..sorry)
Lift ?
Fire protection?
Rigid spray foam. Just had my entire basement ceiling, floors joists, filled and several other walls and cavities.Back when I was building barns. One customer had his sprayed with some kind off foam. Sprayed post framing and metal. Fire proofing and insulation in one shot.
?????Your ether per man or deep pocket man! Looks good !
So in California a 6x6 post would be anchored on top the concrete? Here agricultural buildings are built to different standards. A tornado would be more likely to take it out than an earth quake and they will flex alot before that happens. Post here have tornado anchors on them.Forgive the question....
Why would you place the concrete after the frame? Is this common in your area?
I've been a Carpenter Framer since 1986. I have never seen any job where concrete is placed to the inside of posts like yours appears. We always frame over the concrete and attach the frame to the slab via embedded bolts or straps.
I will admit that I may be out of the loop as to other ways of construction. Out here we have earthquake standards to comply with.
Here is my shop I built in 2006:
View attachment 660588 View attachment 660589 View attachment 660590
Traditionally, the 6x6 would be attached to a 2x6 bottom plate/board with nails or a U shaped bracket. The bottom plate/board is secured to the concrete using threaded bolts that are placed in the wet concrete.So in California a 6x6 post would be anchored on top the concrete? Here agricultural buildings are built to different standards. A tornado would be more likely to take it out than an earth quake and they will flex alot before that happens. Post here have tornado anchors on them.
My livestock barn is a pole type. 12x12 posts set in 3ft of concrete through gravel, with a full hayloft on top. It's 24x24. No concrete floor, gravel about 2 ft thick/deep. I'm having the gravel replenished this coming week after 4 years of use.Traditionally, the 6x6 would be attached to a 2x6 bottom plate/board with nails or a U shaped bracket. The bottom plate/board is secured to the concrete using threaded bolts that are placed in the wet concrete.
I am not in a rural area so there may be different codes. I have been accused of "over-building" things a few times only because this state is bonkers for structural standards.
We all have standards to build by. Here the 2x6 bottom plate would not pass. Wind loads that and everything here in the ground has to be ground rated. To put post directly on concrete would require steel post anchor plates tied to the concrete on each and every post.There is that term..."Frost Line"...
I am unfamiliar with the concept over here. Not bragging, I just have not had to deal with anything like that. No basements either.
The work looks great, please do not take my comments as insults. I do poke and jab people for fun but I try to NOT insult another mans craft.
First time reading this. Geez 12x12 post a bit over kill. Reread and with the overhead hay loft made since. Is the loft foor trussed or joist, center beam with columns?My livestock barn is a pole type. 12x12 posts set in 3ft of concrete through gravel, with a full hayloft on top. It's 24x24. No concrete floor, gravel about 2 ft thick/deep. I'm having the gravel replenished this coming week after 4 years of use.
2x12 Joist w center beams.First time reading this. Geez 12x12 post a bit over kill. Reread and with the overhead hay loft made since. Is the loft foor trussed or joist, center beam with columns?
