68 rr Rear end help? Can u tell from pic?
Answer Book
5:36 PM
fort scott kansas
I have a 68 rr and this is a bad pic of the rear end under it.... can anyone tell just by a couple of bad pics what it is...
what are all the possibilities of rear end for this??
I have very very little knowledge on this subject....
ANY AND ALL help would be appreciated
Heres a 8 1/4...
Heres a 8 3/4...
The 8 1/4 has a cover bolted on the back. The 8 3/4 doesn't have a cover on the back and the center section is removed from the front.
If you have a sure grip, when both wheels are off the ground, both wheels will turn in the same direction when turning one wheel. If its not a sure grip (open rear), one wheel will turn one direction while the other turns the opposite, or the one won't spin at all while turning the opposite.
Heres a 8 1/4...
Heres a 8 3/4...
Thank you very much for the great info and the pics... I think you both nailed it... looks like 8 1/4 to me also
That Differential is NOT out of a RoadRunner. It seems to be out of a low Horsepower Sattelite.
All RoadRunners had 8-3/4 or Dana 60 series rear-ends. A 383 would trash the 8-1/4 pretty
easily.
easily.
WOW!!! thank you for that info... it is a road runner(body and title)... didn't realize wasn't correct rear end under it... very good info... thanks
I don't believe that any 8 1/4 axles were used in passenger cars until 1972. Trucks starting in 1969.
I have a 69 Satellite with a factory installed 383 two barrel, single exhaust. It has a 8 1/4 rear which I'm very certain is the rear it came from the factory with.
Interesting. My originally-318-equipped Satellite has the factory 8-3/4. But, it's a '68.
I've read articles that while on the assembly line, workers were allowed to put "better" parts
on lesser equipped cars when they ran out of Plain Jane parts. I had a Dodge Dart with a slant
six with Kelsey-Hayes disc brakes on the front. When I went to the auto parts store to buy
parts for a brake job, they didn't believe it.
