James Memmel
- 12:30 PM
- Mar 29, 2017
- West Allis Wisconsin
What pushrods do you guys recommend for 440 Victor Max wedge heads
Just looking over my bill from Chicago connection and it doesn’t say a brand but it says they are 8.950” 3/8 and a .083 wall. Give them a call and see what they say bill is a big time mopar guy.
Thanks buddy I knew you know and I was hoping you had the answer.Just looking over my bill from Chicago connection and it doesn’t say a brand but it says they are 8.950” 3/8 and a .083 wall. Give them a call and see what they say bill is a big time mopar guy.
No problem bud. Are you building a new motor?Thanks buddy I knew you know and I was hoping you had the answer.
No the guy that did my motor between the two of us we figured I probably got maybe 2500 miles on my motor so we're just going to do the heads and set them up for the cam that's in my motor and we're going to put them on and see how it goesNo problem bud. Are you building a new motor?
What can are you using with the victors.No the guy that did my motor between the two of us we figured I probably got maybe 2500 miles on my motor so we're just going to do the heads and set them up for the cam that's in my motor and we're going to put them on and see how it goes
Okay are you sure about that cuz I called Chicago Connection they tell me that they would have to have them made they don't have them right there they wanted to know the length so I called Edelbrock Edelbrock says they're 9 and 1/2 in Long so I don't know what's going on hereJust looking over my bill from Chicago connection and it doesn’t say a brand but it says they are 8.950” 3/8 and a .083 wall. Give them a call and see what they say bill is a big time mopar guy.
It's a pretty big solid lifter cam I got my motor nowWhat can are you using with the victors.
Could’ve been a mistake on my work order. There was a couple mistakes i found with part numbers. Best bet would be get an adjustable pushrod length checker and measure what you need. My engine is assembled so I cannot checkOkay are you sure about that cuz I called Chicago Connection they tell me that they would have to have them made they don't have them right there they wanted to know the length so I called Edelbrock Edelbrock says they're 9 and 1/2 in Long so I don't know what's going on here
Well Edelbrock sent me a PDF file on how to check pushrod length and what size pushrod and this that and the other thing so I'm going to look at it tonight when I get home on the computer and we're going to go from thereCould’ve been a mistake on my work order. There was a couple mistakes i found with part numbers. Best bet would be get an adjustable pushrod length checker and measure what you need. My engine is assembled so I cannot check
