moparnation74
This is not for the "faint of hearts".............
I have finally accomplished a task that has haunted me......
Let me describe my "crude" process.....First, hairdryer, waste of time.....WD40 did zero damaged to the adhesive.....Heat gun was not in the cards.......
I pulled out the big balls MAP gas.....Putty knife and a 90 degree pick......I laid the mirror face down on the concrete and ran the torch around the perimeter until I heard "crackling". There is a 1/4" hole on the backside and i used the 90 pick and worked its way in slowly without scratching the mirror. Then I put the heat to it again. So with the tip of the pick facing north towards the edge of the mirror. I her so carefully pried back towards the center. It opened a gap between the mirror and the housing. Then came the putty knife.
The key at this point is DO NOT pry with the putty knife. Now I am using physics, heat and pressure. With the putty knife wedged in tight. I went crazy with the heat with the mirror face down on the concrete and putty knife in place. I went to pick it up by the putty knife and the mirror resided on the floor, done deal...
I finally, finally......still cannot believe have the perfect date coded mirror for the X......When the car gets back in the future. I will update with the install......
What a way to start a beautiful Sunday!
Ohh BTW look at the date on the back of the housing......very fitting......
