Mike Szadaj
- 9:25 AM
- Jan 17, 2019
- St. Clair Shores, Mi
I had this 440 bored out awhile back. As it sat waiting for me to get back to it, surface rust set in. I called around trying to find a place that could take off the rust without ruining the bores. No luck. Then I came upon a You Tube video of some guys using a product called DRX. They put a small block in a tub, poured the stuff in, and it came out looking great. I ended up using Evapo Rust. Since I live in Michigan, and the stuff needs to be used at 65 degrees or warmer, I did it in the mud room of my house, which is only partially heated, using an aquarium heater. Because the stuff is not cheap ($75 for 5 gallons), and I was doing a big block, I had to keep turning it to get it all done. Here are some pics. I think you will agree it does a great job. You can actually get it on your skin with no ill effects.
