- 9:15 PM
- Oct 16, 2014
- Salisbury, Vermont
Here are the numbers...1974 440 standard. Should be all same=same inside as my 1973 440 standard.
I will be merging the best bits together. The one I just got today has 4 pinion front and rears and a hardened output shaft so I will be using those along with the front pump from the 73' and tail housing from the 74. I have not taken apart the clutchs yet, so I don't know which steels and frictions are better,...Output shaft splines change in 1976 so you should be good. Personally I'd just keep the front planet with its original output shaft. 3 or 4 pinion makes no difference. We run 3 pinion over 800 hp with no issue.
