Garys1969RR
Every copper gasket I looked at requires O rings. So not sure whats going on there. Also wondering why copper works with Aluminum heads, while steel shim is not recommended. Cast iron, copper and aluminum all expand at different rates. But these heads were sealing fine, no evidence of leakage. I have used steel shim gaskets with aluminum heads before, and they sealed fine. Has anyone else had good luck using the steel shim type with aluminum heads? Thanks. Oh, these are the Stealth heads.
