Why would I do that and miss all this fun? Plus that car has a straight axle I want torsion bars.You could buy this one and skip all the dirty work: https://www.ebay.com/itm/1965-Dodge-Coronet/264226195778
The car on ebay is a really nice car with a Hemi and electronic fuel injection and a two door sedan that has a stock wheelbase. What RVW is trying to replicate is a factory built altered wheel base 2 door hardtop car, and at the rate that his car is going, he will have it finished soon. And---it's a father son project ! How cool is that?You could buy this one and skip all the dirty work: https://www.ebay.com/itm/1965-Dodge-Coronet/264226195778
Just finished doing a set of awb 65 Plymouth fenders for Art Thiabald and friends.
I got my motor plate yesterday and measured out to where mine would fit . With the motor set back it would go even with the top shock hole . Will make a cardboard template and cut to fit .Also I have gasket matched the water pump housing and block and will do the same with the ARC motor plate . this will help the water flow thru to the water pump and not have any restrictions . the ARC plate is 3/8 inch thick and has a matching lower pully spacer to get the correct belt alignment . Mancini racing sells both. Hope this helps Johngot the new transmission crossmember in and starting to mock up the engine placement. Decided to go with a engine plate so we have to make up some unique mounting brackets because they will mount on the "clam shells. The white lines on the clam shells is where the mounting brackets will go if we stick with the stock engine location. Also decided to go with a gear vendors unit. Also got the Hiliborn Intake modified for the electronic FI.
View attachment 735595 View attachment 735596 View attachment 735597 View attachment 735598 View attachment 735599
Looks good thanks for the pictures you are a lot farther along than we areI got my motor plate yesterday and measured out to where mine would fit . With the motor set back it would go even with the top shock hole . Will make a cardboard template and cut to fit .Also I have gasket matched the water pump housing and block and will do the same with the ARC motor plate . this will help the water flow thru to the water pump and not have any restrictions . the ARC plate is 3/8 inch thick and has a matching lower pully spacer to get the correct belt alignment . Mancini racing sells both. Hope this helps JohnView attachment 741866 View attachment 741867 View attachment 741868 View attachment 741869 View attachment 741870
Kinda have come to a screaming halt on the A/FX for a couple of months. Got to get one car done for West MI drag week end get my 66 Dodge back up and running. Just took the 64 Plymouth that we have been building to the track for the first time. But have been getting the old school Hiliborn injection modified for electronic FI. Have all new butterflys fitted to the throttle bores. Turning out pretty good for just mock up now.
View attachment 750101 View attachment 750102 View attachment 750103 View attachment 750104 View attachment 750105 View attachment 750106
Contact Sled City FiberglassDoes anybody know where I could get a look at one of the 12 original A/FX cars?
