- 2:30 AM
- Jan 29, 2018
- Midland Ontario, Canada
Vent frame channel up stop / rail cap.
Installed. There is a left and a right.
I'm so sick of AMD glass and wish I'd bought it all from ECS, not AMD through National Moparts.
This is nobodies fault but my own. I picked it up in person and should have inspected it on site before leaving. Scratch right in the center of the door glass. That and finished shape compared to OE is sad workmanship to say the least.
Lift channel attached to new glass with "gasket" and new plastic rivet. Pin on rivet not set yet.
New OEM slider felt, measuring down 5/8 from top corner similar to my OE set up.
Just happens that is the exact distance the hole punch will reach from an end!
Showing this "mistake" so nobody else makes it! Hole is too close to the bottom of the felt / edge of the glass.
Test fit shows the hole being where I punched it puts the felts about 3/32 too far out from where they should run in the channel.
Also appears I have a burr somewhere and shows how easy these felts tear.. break out the riffler files. Fortunately I hadn't cut the felt to length yet and had enough left to redo the end.
