Also does anyone make a socket/wrench for the ignition switch nut? Part #?
How about molded styrene letters?View attachment 754743
So here's my current dilemma. I'm using the second rocker from the right to power my GearVendor overdrive. I'd like to put a raised font that matches the other switches underneath it and on/off to the left side of it. Anyone have any ideas. I don't really want to just slap a sticker on there. But I may have to resort to something like that.
I think I'll also wire in a relay to cut power when in reverse, I've heard that is hard on them.
You’re welcome! I was a train geek once upon a time! HahaThanks Mike! Now I know where to look.
So I finally got some time in the garage over the weekend! Yay. First I installed the hard to find Tbolt I was lucky enough to receive from a great friend! Thanks Justin
View attachment 754249 View attachment 754250
I used a dimmer switch under the clutch pedal to activate mine and also have an arming switch so I can disarm it for racing. I’m gonna investigate the features of that electronic control box once the car is up and running.I'm back on overtime but took a little time to work on the dash. Still looking for some lettering for switch panel.
I used a flasher switch for the overdrive activation.
I gave them a great home!So I finally got some time in the garage over the weekend! Yay. First I installed the hard to find Tbolt I was lucky enough to receive from a great friend! Thanks Justin
I made my own out of a washer. One is for my 62 bezels, the other is for my 69.Also does anyone make a socket/wrench for the ignition switch nut? Part #?
That is a good idea. I'm going to make me one.I made my own out of a washer. One is for my 62 bezels, the other is for my 69.
Also, what rear tires are you running Tim?
