69 gtx
Also does anyone make a socket/wrench for the ignition switch nut? Part #?
So here's my current dilemma. I'm using the second rocker from the right to power my GearVendor overdrive. I'd like to put a raised font that matches the other switches underneath it and on/off to the left side of it. Anyone have any ideas. I don't really want to just slap a sticker on there. But I may have to resort to something like that.
I think I'll also wire in a relay to cut power when in reverse, I've heard that is hard on them.
How about molded styrene letters?
http://www.railwaymodels.com/catalog/materials/7
There’s lots of other vendors that offer these as well with various sizes and fonts.
So I finally got some time in the garage over the weekend! Yay. First I installed the hard to find Tbolt I was lucky enough to receive from a great friend! Thanks Justin :lowdown:
View attachment 754249 View attachment 754250
'69-Where does that "T" bolt go? Looks like around the ash tray(?) Reason I ask is a friend of mine has a 69 RR and we was talking last night about it and he doesn't recall seeing one. But then yet, his car has been apart for years. I have a "T" bolt if he needs one
Torr Red they go on the inside of both hockey sticks. I don't think RRs use them because they don't have these trim pieces.
I'm back on overtime but took a little time to work on the dash. Still looking for some lettering for switch panel.
I used a flasher switch for the overdrive activation.
So I dug out the old harness. This reminded me of the horror I found when disassembling the dash. You never know what's hiding out of sight.
I found the flasher connector and cut it off to use on the OD switch.
Then I kinda laid the new harness in to see how it fit. I did notice the new connectors are really tight going on so I just pushed them till they held as I'll probably be taking it back out for something.
I used a dimmer switch under the clutch pedal to activate mine and also have an arming switch so I can disarm it for racing. I’m gonna investigate the features of that electronic control box once the car is up and running.
69 GTX-Thanks for the reply. I'm not sure what my friends dash looks like but will pass your info on to him just in case.
Cut the old flasher pigtail off and removed a lead. Found some terminals that'll work for wiring it up.
I made my own out of a washer. One is for my 62 bezels, the other is for my 69.
Also, what rear tires are you running Tim?
So I got the call from Wilson Products, my restored latches are on their way! Just in time, I'm taking next week off to work on the car. Going to try and concentrate on window mechanisms, door latches, dash, & wiring. Also the good grille if I get a road block. Should be plenty to keep me busy! :thumbsup:
Well day one of carcation week. Took the better half to the early show (movie) mowed her yard, cleaned the maple seeds out of her gutters. Mowed her widow neighbor ladies yard. Kissed her & the dog and headed for my place. Got my yard & gutters cleaned just as the rain started. Garage time! So I walked in and unboxed my door latches I had Wilson Products of St. Louis do. Looked nice. I couldn't bear to put them back on no matter how nice I had them cleaned so sent them out. Very happy with them. Turn around was about a month, not bad.
So in a effort to clear table space I picked something off the table to complete. Bucket seat tracks. I had them apart, blasted, and painted. Just needed to reassemble them. Took me a while to remember how they went together.
