I am installing a new champion 26" down flow 3 core radiator in my 67 Coronet.
I have a question about fan depth in the shroud with my fixed 18" mechanical fan and spacer the fan blades are all the way into the shroud, Shroud is older C body plastic.
The fan blades are 1 & 1/2" back from the core.
To pull the fan back out of the shroud some I can use a shorter spacer but I am not sure how far back I can run off the core and still have good low speed air flow? I know most folks say to have it 1/2 way into the shroud
Or should I leave it in the shroud and closer to the radiator ?
In the near future there will be a A/C condenser in front of the rad also.
