Dibbons
- 1:09 PM
- Nov 29, 2014
- La Paz, B.C.S., Mexico
I read over and over the same suggestions for Mopars, how to get max caster, then set camber, then toe-in, like is explained below:
"Start with the ride height, then set the front cam all the way out and the rear cam all the way in. Then bring the rear cam out until the camber is in spec. This is the maximum caster that you can get with this car. Then set the toe."
But I don't know, and can't picture exactly what is meant when it is said "all the way in" or "all the way out". I know there are two bolts with some offset washers, but I can't get it straight in my mind what is "in" and what is "out". I know you turn the bolts, but the description of this orientation has me confused. How do you bring a rear cam "in" and then "out". "In" compared to what? "Out" compared to what? I know it must be a simple concept, but it is all Greek to me.
Thank you.
Thank you.
