mopar 3 B
- 11:33 PM
- Aug 25, 2014
- Kingsville, MO
What's your time frame for replacement?
I have to get my front suspension done before I upgrade the rear end so not in any hurry. This is why I am researching and wanting to know what I actually have to work with. Unfortunately my health is not that great and just getting under the car is difficult for me.What's your time frame for replacement?
Kern, I didn’t take it as being rude.....I probably came across as rude before, sorry for that.
The Dana Corporation has made a variety of axles for GM, Ford and Chrysler. Chrysler did make their own for the most part. I have heard people call the 9 1/4" axle the light duty Dana but I think that people use "Dana" like some use the term "Posi". It gets the point across but isn't correct.
Back on point:
I counted the bolts as best as I could since the OP did not provide a better picture. I can understand though, without the car hanging in the air, he surely got the best picture that he could.
Regardless, I recognize the shape of the cover. They were certainly offered in the 1970 models, I have seen several. They are stronger than the GM 8.5 axle and you don't have to worry about the C clips breaking off, launching an axle shaft out the side!
KD Did you get inside the case at all? Any idea about the carrier size? I need to figure out what is needed to upgrade my gears and carrier possibly as well.My '70 Charger had a 2.71 geared 8 1/4" axle when new!
Thanks I will! Looks like I need a 27 spline not 29 spline as those were for newer applications.Sorry, I wasn't "forward thinking" enough to save it, inspect it or do anything with it. I should have. I thought the 2.71 diff worked with the 3.21, 3.55 and 3.91. I was told that the 2.45 that came along later was the orphan that had its own specific carrier.
You could contact Shawn at River City Differentials in Sacramento CA 916 852 7109.
Is the lower-right a Sure-Grip ?I count 9 bolts but it does not match any of the rear ends identified in the chart. My goal is to add a sure grip if possible but I need to identify it first.
Thanks MF
View attachment 745525 View attachment 745526 View attachment 745527 View attachment 745528
2.56 and higher was the cutoff on the carrier. Lots of info in this thread. Grab a track lock from a dana 30 jeep and you have a great rear. A lot of them came with 3.55 also and drop right into a 8.25Sorry, I wasn't "forward thinking" enough to save it, inspect it or do anything with it. I should have. I thought the 2.71 diff worked with the 3.21, 3.55 and 3.91. I was told that the 2.45 that came along later was the orphan that had its own specific carrier.
https://www.forabodiesonly.com/mopar/threads/the-8-1-4-thread.350667/
