Yeah, not real easy to set up a control arm in a press, hold it in place and then grab the handle on the bottle jack. Having a motorized press pump and a foot switch would be real handy doing this stuff.It was a bungee cord to hold up the end of the control arm so I could set up every thing to press it down. It worked great
No PST with my discount belonging to this forum great deal . I bought a rear sway bar also.Firm Feel sway? It looks like it and I have theirs on my car
I bought a press at Harbor freight it actually worked real well for doing this kind of job it was actually fun doing this it wasn't as hard as every one says it is .Yeah, not real easy to set up a control arm in a press, hold it in place and then grab the handle on the bottle jack. Having a motorized press pump and a foot switch would be real handy doing this stuff.
I didn't get to finish the PST sway bar they sent me to long of a bolt and spacer so I made measurements and emailed them what I need...
Yeah, same issue here, do you mind sharing your measurements? they had me send them a bunch of pictures, bolts and shaft way too long...
The pictures are above unless your asking for something different.Yeah, same issue here, do you mind sharing your measurements? they had me send them a bunch of pictures, bolts and shaft way too long...
Thank you James yes Dan contacted me and we are working on it I appreciate it. The only problem I had with communication was I called twice on Monday and left a message for a call back and know one called me back it wasn't till I left a message on our website that Dan responded.Hello Doug,
Im following up with our customer service department on your issue. I see that you are working with Dan here and he has received your photos of the bolts and sleeves in question. I have confirmed with him and he is in the process of getting replacements that are shorter. to you If you have any further questions please let us know.
James From
PST
Lol well they do keep you warm but they're just regular lights from Home Depot.Amazing what the "heat lamp" does...
I'll be getting to that when I get done with the passenger side thanks for thr inspiration ha ha.
I'm still waiting on my mid section new spacer and bolt when they come I'll check it out and get back with you. Thanks for the heads up. The more guys who buy there product for our year cars if we're having issues it's good they know 71-74 chargers are all not the same like some mfg think they are.Hey Doug, on the PST Swaybar, have you noticed how the bracket that attaches the swaybar to the strut arm hits the k-frame when you push the LCA all the way up until the bump stop makes contact with the k-frame? I am having that issue, will look at it closer today, was wondering if yours was doing the same and if you had to modify it... I even tried reversing the bolts... too close / hits.
View attachment 775007 View attachment 775008
I'm leaving town for a week so I won't even be able to get to it for a couple of weeks anyways so like I said when I figure it out I'll let you knowI just got mine and they are still too long... i can flip the swaybar with the bow towards the bottom which works but makes the swaybar hit the kframe... the other way it doesn't work, the spacer and bolt are too long... which doesn't really matter i can cut it down and buy a new bolt... but still... i have a lot of concerns it should just fit correctly... debating on returning mine or sticking it out and working with them. At the very least i can say they do listen and work with their customers.
