Charger Dana
Try removing the driver’s torsion bar. That’s the key. Should be enough room.
No need to remove the t bar if you follow the above routine. Done it many a time on my 440Try removing the driver’s torsion bar. That’s the key. Should be enough room.
Thanks! I’ll try that next time. It’s the stock starters that tick you off. Especially with big tube headers.No need to remove the t bar if you follow the above routine. Done it many a time on my 440
