Starter removal
I know this is an older post but looking for clarification. A lot of you suggested unbolting the driver side motor mount and "unbolting" the header. Are you referring to unbolting the collector and "loosening" the bolts going into the head or completely removing the bolts from the head so the whole header is essentially able to just come out?
From the head and take mounts loose to gain some room. Make sure that no children are around because they may learn a new language. Good luck
