67 Plymouth spring and mini tub mod
10.5w, damn
This picture is that same W tire on 15/12 rims with 6.5 bs section width is around 14 across
Hope this picture gives you a idea
Something on the back side of the hinge is hitting the tub about halfway down when trying to close it. Are those supplied brackets just fillers to connect the hinge back to the tub? I'm an idiot, I welded those in to support the front side of the wheel well.it fit perfectly. Lol
[QUOTE="Are those supplied brackets just fillers to connect the hinge back to the tubQUOTE]
Yes that's what they are for...... I think there was something in the directions that said you can get in the trunk with a helper and close it then mark the spot it's hitting then wack with bullpen hammer
Thanks!
Got a little burnt out on body work so started putting the rotating assy together. Installed the bulkhead, filled the pan with water to check for leaks.
