Lay rags over the tips of the rockers, start the engine with the valve cover off and use a stethoscope on each of the rocker arms. You will easily notice the loud one.
You dont even need the stethoscope. Put your finger on each rockerLay rags over the tips of the rockers, start the engine with the valve cover off and use a stethoscope on each of the rocker arms. You will easily notice the loud one.
Well darn, great advice, I wish I had run it with valve covers off before I pulled off the intake manifold. Gotta wait for the fresh manifold to be installed (eddy RPM, need to block heat risers) before I can do that check. I suppose I could go ahead and replace lifters now since a set is only $50. It would be worth it not to buy a new gasket set, drain coolant and remove manifold again to get at them.
I can check pushrods and tips while im at it.
I just realized this morning that i F'ed up, tightened down the timing cover with sealant around pan corner on bottom before dampener was installed (supposed to be on to center the seal) so that may complicate things. Praying that I can loosen all the fasteners, pop on the dampener without breaking seal with oilpan.
It does not, and there is some play allowed between the size of the holes and the bolts that go in them. Fingers crossed. Had to push down very hard against the bottom oilpan seal (half-round rubber one) to get the timing cover bolts threaded in. Fingers crossed that its close to alignment with the dampener.If your timing cover/block has dowel pins, you're not going to move it much anyway.
Unless you have a windage tray on your engine that busted piece should be in the pan. If you do have a windage tray I would start pulling it apart... sucks when the gravity switch is left on...OK so I was able to go home tonight and do a little bit of work and found some interesting things. Took all the lifters out, about half of them were rock solid (cant get plunger to depress even with a screwdriver) and the other half were able to be depressed with a finger. I am wondering if this is because the ones that were under pressure all this time from the valvesprings collapsed, and the lifters that weren’t stayed pumped up. Not sure, but I already have a new set of lifters on the way.
I cleaned and checked all the pushrods, they are all straight and seem in in order, although the top ends were rusty probably from sitting for a while and not running for long periods (before I bought the car). Some time in my wet tumbler with steel pins cleaned them right up.
I found something interesting when looking at the old intake, it appears the heat riser on the drivers side was crudely plugged and leaking. As much as I want to point to this as an “aha” for the ticking sound, I had isolated the sound to the opposite side of the motor so maybe it’s just a coincidence. Either way, I am really looking forward to getting rid of the exhaust crossover and fuel boiling off. Losing 40 pounds on the front end from that cast-iron manifold is nice, too.
Finally, when pressing the old lifters out I was using a plastic rod to try to pry them from underneath without scratching the lifter face (thinking i might re-use them) And the thing snapped and dropped about a 1/2 inch long piece of plastic rod down into the motor. Can’t see anything with a flashlight, no idea where it went. Oilpan I hope.
View attachment 796227 View attachment 796228
