wsutard
I’m looking for some advice on tuning my Holley Double Pumper 850 on a fresh 440.
My issue is with the primary transition from cruise to power. As I give minimal to heavy throttle the engine is leaning out to the point where I get lean surge or feel the power of the engine reduce.
My AF gauge will go from reading 13 to quickly 17 or even —-. Then it will bounce around up there and eventually drop back down to 13-14.
This is all in the primary bowl. As soon as the secondaries kick in I’m immediately back down to 12.
In its stock form the Holley was very rich but never showed lean out issues. The stock jets are 80 with a 6.5 PV and 31 accelerator pump nozzle. My AF would always be 10-11 with this setup.
I’m at my wits end trying to figure out how to get more fuel from the primary’s without going rich on cruise. Outside of asking here my next step is to try a metering block with adjustable PV ports.
My current setup is as follows:
72 jets
40 nozzle
8.5 PV
Black cam on setting 1
Stock accelerator pump spring and bowl
10 vacuum
12 advance with 32-33 all in
Forged internals 440
Mew MSD box and new MSD distributor with no vac advance.
Engine dynoed at 520-550 HP.
I have tried jets all the way from 79 down to 69. I have PVs from 8.5 to 5.5. I have 31, 35, and 40 accelerator nozzles. I can not find a combo that gives me good cruise mixture but has the fuel I need for the transition into power.
I’m sure I missed something to please let me know if there is some critical info you need.
72 jets
40 nozzle
8.5 PV
10 vacuum
Helpful when dialing in a vacuum advance as well.
