1 Wild R/T
No, we don't want to scare him off.. But we don't want to feed him wrong info either... The low deck Mopar's are hard to build compression in do to their short stroke and cylinder head design...
The easiest why to do it is with a domed piston but then the flame travel is effected & not in a good way...
So you choose the best flat top you can, mill the crap outta the heads & measure closely to see how much cam you can get away with...
Another thing to keep in mind is with todays fuels if you run iron heads you really don't want to be at 10-1... I guess some areas get better fuel, here in California gasoline & cow piss are interchangeable... so with 91 Octane 9.5 is about the limit...
