Missing spark on my 6.1 Hemi, Charger -70.
MikkoV
1:14 AM
Finland
I installed retrofit Mopar PCM kit from Swap Specialties to my car (1970 Charger) last weekend, it has been running couple years with aftermarket ECM called Tatech, but it didn´t work like streetcar was supposed to, so...
Kit uses PCM from -09 Challenger 6.1 M/T
Just this minor problem, it doesn´t start. I´m missing spark, +12v coming to coils but no pulse. Everything else is fine, no major fault codes, got rpm signal, fuel pump works when starting and there seems to be injector signal.
Any ideas where to start looking?
Can anyone point me ground pins on PCM connectors, cant find more than C1-9
Lack of a cam and/or crank sensor signal will usually result in a no start condition.
Ignition switch, do you have 12volts while cranking?
