Yep - I'll get one this evening after work.Say could you send a pic of your set up?
Just to clarify, you are using the T for the front disc brakes and the prop valve is going to the line for the rears (which tees off by the differential). Correct?
CorrectJust to clarify, you are using the T for the front disc brakes and the prop valve is going to the line for the rears (which tees off by the differential). Correct?
What did you do for the brake failure warning light that's part of the distribution block? Just eliminated it?Correct
