I like that better too! I asked him about that a few years ago when he did mine. I don't recall exactly what he said about it but was not doing it at the time. Guess he got it done now. I'm gonna send mine back for an upgrade. Thanks for the heads up.I have been using Shannon at Redline Gauge Works for the past 3 cars I've done and been happy with the results. The one thing that always bothered me though was on a amp to volt meter conversion, 12 volts on the scale was always straight up and when the car is running the needle is way to the right. So he told me it is no big deal to modify things and put the 14 straight up. I like this a lot better. Of course I am the only person who has ever asked for this modification.
View attachment 867628 View attachment 867629 View attachment 867630
Better pic of the volt gauge. Didn't mean to create any more work for you Ed....I like that better too! I asked him about that a few years ago when he did mine. I don't recall exactly what he said about it but was not doing it at the time. Guess he got it done now. I'm gonna send mine back for an upgrade. Thanks for the heads up.
Oh well.........Not like I don't need the exercise. Where are you installing the speakers?Better pic of the volt gauge. Didn't mean to create any more work for you Ed....
In the spot where the stock 4x10 goes in the dash.Oh well.........Not like I don't need the exercise. Where are you installing the speakers?
Motor is supposed to be getting put on the dyno this week if everything goes as planned. Brian at IMM in California is putting it together for me. He did the 408 in my Duster and I am very happy with that one. He talked me into stroking the 400 to a 499.Maybe I missed it, what is the plan for the engine on this one? With the progress you are making so quickly, and your geographic closeness, do you plan to have this at Mopars in the Park this coming summer?
I was originally going with a 470. The goal was 550 hp and 550 ft.lbs. But because of the Ramcharger ductwork I ran into height issues on the intake to get everything to fit. Ideally this motor would have an Edelbrock Performer RPM or a Holley Street Dominator. So instead we are using a Weiand Action Plus that Brian is going to work on a bit. Because of that and the fact that I want 3.23 rear gears, he talked me into going with a 499.Make sure you post a dyno sheet! Did you have any goals you gave him for the build, or did you just turn him loose?
Yeah, thought I better get going on some of this small stuff since the car will be back home within a week.Coming up on the fun part, installing them!
Doesn't someone sell the whole vent window brand new? If so, they must reproduce those small parts, too.One thing I did find out is that both the flat washers and black pivot bushings are not reproduced or available anywhere. I am still on the hunt for a couple nicer bushings, but for now reused my originals. For the flat washers I picked up some made from neoprene at our local Ace Hardware. Found some with the correct center hole, but the were to big diameter. Made a punch from a piece of 3/4" emt conduit. Put in some new stainless screws and called it a day.
View attachment 869613 View attachment 869614
