One more 69 road runner build
This is where things get tricky Jed moved on to the valve body where there are several modifications needed.
This does require very close attention to detail, as there are many fluid circuits, check balls, and orifices that need modified. The instructions provided cover these details very well. This kit was also provided to us from Cope Racing Transmissions. According to the instructions I’m going to spill my coffee
525C2B63-2BD4-4613-A332-92E0947CF5CC.jpeg DE828941-0209-4F40-9637-061C2729BF39.jpeg F9CCCB6E-BBB9-424C-A456-75A4DF8504CC.jpeg D75C338B-DDBD-4E57-BBC5-086DC58776C7.jpeg 2B75E737-9060-4C1C-BADC-769D05A1334F.jpeg
Time to button things up
Jed installed the valve body filter extension and filter with a new deep steel pan and molded gasket.
The filter extension will allow the filter to remain deep in the pan where the fluid is less areation. The extra capacity will also offer some additional cooling.
893F996B-86F9-4A68-BAF3-72E2FFC6A7DA.jpeg 62345E80-D270-4F19-8CBA-D4C4E6325966.jpeg 504B29F3-3D41-4ACA-98B4-5FFD4117E826.jpeg A9738094-A73E-41D8-9D81-971F378212C1.jpeg
Did some work on the brake pedal assembly. Replaced the nylon bushings cleaned and detailed brake light switch and bracket repainted brake pedal arm and replaced brake pedal pad
EE421144-BD8B-46AA-AFF1-FEEE266D6D25.jpeg CD18297A-F0B8-4CC9-9AE1-167C6AAD5598.jpeg 0DBF0BAF-D9D1-4D13-B6C9-F0AB88564896.jpeg
Here are a few pictures as I completed the process. I disassembled everything and soaked it in the
Evapo-rust. The final finish is glass beaded and clearcoated.
8F137B9E-62D4-48A7-A310-831E8D202358.jpeg image.jpg image.jpg image.jpg image.jpg
Also similar process on the E brake.
Soak everything in Evapo-rust. Cleaned the switch all the hardware repainted brake release
I still need to purchase a new pedal pad and this will be complete.
For 50-year-old plus parts the E brake and brake pedal assembly look pretty good with some elbow grease and a little detail
0CE96FC7-F518-4765-84FF-38CB277AFF80.jpeg 1D28D399-EFFC-4E5B-9D2C-3B7650A96C2A.jpeg BAFDFC82-3314-4C2A-9DDB-70BB6C8B0781.jpeg image.jpg image.jpg
Did some work on the horn
It still works but sounds a little bit sick like the coyote might’ve taken a bite
May have to replace it with an aftermarket one but for now I have a semi restored Spartan.
I got the correct color from Totally Auto.
407E9B0D-5879-4108-B297-7F33751F2B6A.jpeg 0F731C6D-4C38-4CAE-9D9B-E50E38C7509F.jpeg 8ADD5CA6-A609-4F66-A2C5-2DA1C69838E6.jpeg F0F4F582-6DE4-47A6-B323-E774A2DD4A30.jpeg image.jpg image.jpg
Got the main body on the rotisserie took it to sandblast did not have quarters or roof blasted and stripping those By hand
0C59F0E1-FD6F-45AC-8A8E-21599BF0354D.jpeg 19E9FD41-ADFF-49BB-895C-DCB6DD4BBBC3.jpeg EB2AF0D0-61DD-4074-90A3-813400FA7386.jpeg
This car is almost rust free however as with most there are a couple areas that need replaced. Dutchman and passenger rear foot well have been removed. I have AMD replacements ordered.
FA4B0E17-E3F9-4964-8E92-656E925469E1.jpeg 2A8BD637-5AF6-401B-8DE8-73CC594E9734.jpeg 2B8F61B4-E8ED-4FEC-BE42-9BA555F8C325.jpeg
Worked on putting the consul brackets that had been cut out back in and aligned
FF53909C-9413-41AC-BCFB-5B02B0AD35B7.jpeg 77152F75-3B51-4551-B56C-C82DB5E870EE.jpeg
Great project. Nice to see rust free examples are still out there.
I love the breakdown of the trans rebuild as I really enjoy working on them.
