wyrmrider
yep those with lifter pump up or valve float pay attention
other side of the coin is that valve close is easier
I think your rocker shaft needs to go down relative to the valve tip. Try the lash caps with no shims.
You cannot make the geometry correct with those stupid Mancini shims before you run out of/off of the valve tip. And you can make it worse with lash caps and lowering the rocker shaft. Run what you have and you will have no problems with your cam. Or you can make it better by working with B3RE!!!!
Ordinary shims do not do the trick.
See how the B3 kit moved my rocker shaft, up and away from the valve.
See the contact pattern before and after.
Micheal from B3 is a helpful guy and will set you up with a kit to get it right.
He will send you a sheet to complete some measurements.
A side note is, that you must be prepare to elongate the bolt holes of the rocker shaft to give space for it to move off-center.
View attachment 914800 View attachment 914801 View attachment 914802 View attachment 914803 View attachment 914804
but since you have them...
