Fan/Pulley Question
westie47
10:26 PM
Abbotsford, BC
Do small blocks and big blocks use the same sized fans and pulleys?
I have a 7 blade fan on my 360 and wondering if it’ll work on my 440? Same with the pulleys, they look to be the same size.
The length of the shaft are different on the fans
This is so the fans are the correct distance away from the radiator
The big block sits closer to the fan so the shaft is shorter
Just a guess on this one but I doubt the pulleys will interchange due to the length of the water pump snouts
Depends on year, options like p.s. a/c etc. Water pump depths differ for small block early/late. I have found several big block water pump pulleys that differ too. Some single crank pulleys are the same.
Is the overall size of the fan blades the same? I notice the bolt pattern is the same, just wondering if a big block fan has bigger blades
By shaft length, do you mean the spacer? I’m not quite following.
The shaft coming off the front of the water pump. Sort of like this:
There's dozens of different size/shaped pulleys depending on accessories, as Darter6 said.
I wouldn't count on re-using the pulley, even if it will physically bolt onto your big block water pump. You 'should' be okay on the fan though.
I should have explained myself better and I had a brain fart
I was referring to the viscous fan clutch fans
I forgot about the simple fan/spacer combo
But as Suregrip stated each water pump combo requires a matching set up
I do apologize for any confusion I may have caused
No worries, mine is just a regular fan. I believe the clutch fan was for heavy duty cooling packages?
yes mostly
It also used in performance applications because it doesn't eat as much horsepower
I bought one years ago from Mopar Performance and it hit the radiator on my big block
This is how I learned about the different shaft lengths and the first thing that came to mind when I read your question
