Modern Bullitt build
Installed the right side rear power regulator and like on the door I had to cut an opening to allow the crank handle switch.
This is a continuation of the first post, pictures are in order I installed the parts for the regulator. I missed taking a picture of sliding in the long track from the top that holds the two spring rollers.
Pat
Pat, do you buy all of those bolts and fasteners, or are they restored/cleaned originals?
I use all the original hardware and fasteners. I cleaned and restored most of them as I removed them from the car 5 years ago.
Amazing! I've had very little luck on cleaning up those bolts and not losing the black phosphate (?) coating...yours look brand new.
Love the work you're doing!
Now with the rear wheels on I could finish up the rear brake cooling ducts. I had made the air intakes and modified the Torque boxes before painting the bottom of the car 2+ years ago. But I did not have the rear installed at that time so I could fit the wheels to make the disk brake plates until this weekend.
I fabricated the front caliper cooling vent this weekend. Had a hard time finding a piece of 2 inch OD aluminum tubing until I got into my son’s golf bag and found his golf ball picker-upper tube. Cut off about 3” and put the cap back on. He will never know that holds two less balls;-)
Pat
I received the 2nd version of my custom 3D printed fender tag from Dan at http://www.nextgendesignsnc.com/ . We made a few changes in the font size, letters in the alphabet and spacing. Hope to paint it black and install it on the inner fender soon. Dan is great to work with, and I’m very happy with the tag!
Pat
Just asking......shouldn’t that be “usb” instead of “ubs”? Looks freakin killer!!
Rear brake coolers painted and installed. Still working on a few ideas for the air intake screen.
Pat
