- 10:40 AM
- Oct 18, 2008
- Kindersley,Saskatchewan, Canada
If u need lots more neg camber u can install A body lower arms. Their a 1/2 in longer. Kim
My red car is at 3/4 degree negative but only 1/8" toe in. It is the toe setting that will chew tires faster than camber.Where are you wanting to set the camber at? I had mine set at -1* and my tires wore down on the inside in only a few thousand miles...
Holeee crap...do you know how much negative camber that would get you ? Probably 10 degrees !If u need lots more neg camber u can install A body lower arms. Their a 1/2 in longer. Kim
You mean caster, right?I know a couple of guys that have put the B body arms on their A bodies to get enough pos camber to their liking. Kim
2 degrees on my car. Ask me how I know.Holeee crap...do you know how much negative camber that would get you ? Probably 10 degrees !
Can ya even see 2 degrees looking at it from a distance?2 degrees on my car. Ask me how I know.
(adjusting bolts all the way out)
